Report top 10 of recurrent alertes
cyrill_gremaud
Participant
I want to know if is it possible to create a report with, for example, the top 10 recurrent alertes or problems that occurs since a period of time.
thank you
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Hi Cyrill,
By using our problems REST API you can fetch the history of all problem details and which monitored components were affected most.
See following documentation:
https://www.dynatrace.com/support/help/dynatrace-a...
Wolfgang
