AI Feature for the External/Integrated Data
Babar_Qayyum
Dear All,
Will the AI apply on the data sent/pushed (PurePaths/Metrics) from the Dynatrace AppMon & DCRUM after integaration?
Babar
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
The Dynatrace AI will automatically connect the Smartscape relationships and also use the additional evidences within the causation process, such as DCRUM/AppMon metrics and events.
Best,
Wolfgang
Hello @Wolfgang B.
Thank you for your comments. In short your answer is YES regarding AI for the external data.
Let me explain a bit more about the scenario so I can get better assistance from you.
  • Dynatrace platform will be installed and integrated with the Dynatrace AppMon and DCRUM.
  • In the Dynatrace environment applications will not be instrumented with the OneAgent.
  • Dynatrace AppMon data will be pushed/transferred to the Dynatrace to get the benefits of AI/Machine Learning.
Do you think that in the above situation someone can have a real value of AI?
Do you think that for the time being we can use the said scenario to show something valuable to AppMon customers?
Please share the maximum relevant information so I can discuss and share your thoughts with the relevant persons.
Babar
