Request Body Node.js
komchan
Visitor
Hi
i use dynatrace managed.
I monitor Nod.js. I want request body and how to show request body
hayden_miedema
Inactive
Hi Komchan,
The OneAgent does not capture the request body as this can vary in size and can cause lots of overhead to an application. Are you looking for a specific part of the request body? For example, certain header(s)? If so, you can setup these to be captured by going to Settings --> Server Side Service Monitoring --> Request Attributes. Request headers, response headers, URL parameters, Java and .NET method params can all be captured.
Hope this helps,
Hayden
