Is it possible to monitor certificate status using Dynatrace?
apasoquen1
Helper
JamesKitson
Dynatrace Guru
Dynatrace Guru
I suppose if you could write a python plugin which could check the certificate status and return a metric that would be doable.
https://www.dynatrace.com/support/help/monitoring-...
James
