Dynatrace API entity/applications does't contain synthetic apps
Bert_VanderHeyd
DynaMight Pro
DynaMight Pro
When I use https://*****.live.dynatrace.com/api/v1/entity/app... to fetch all applications, we don't get back the Synthetic applications.
Using the timeseries API to request the bouncerate, we do get these application id's back.
https://******.live.dynatrace.com/api/v1/timeserie...
Looking at the documentation of the entity API, one of the applicationTypes should be synthetic.
While currently we only see. DEFAULT, CUSTOM and RUMONLY returned.
Is there a reason for this behavior? Or is it an issue?
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Hi Bert,
The type synthetic is a bug in the documentation. The application endpoint was not meant to deliver the synthetic tests. We are in the process of offering a separate /synthetic endpoint that will deliver the synthetic test entities.
Best regards,
Wolfgang
Ok, thanks. Keep me posted on that new Synthetic API please.
