vFire (Alemba) ITSM / ITSSM integration
graeme_wilkinso
Dynatrace Guide
Dynatrace Guide
A New Zealand partner (Fujitsu) asks if Dynatrace has an Alemba vFire integratiion planned, or if anyone is successfully directly integration with this service-management platform.
4 REPLIES 4
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
No such plans but by using our REST APIs all raw information is easily accessible from the Dynatrace side.
paulchristopher
Newcomer
Team - Can you let us know if there is any update on integrating Dynatrace with vFire? Any references or samples ? Appreciate if you can provide any guidance on the Custom integration of the vFire
paulchristopher
Newcomer
@Wolfgang B., @Graeme W. : Can you let me know if there is any update on integrating Dynatrace with vFire? Any references or samples ? Appreciate if you can provide any guidance on the Custom integration of the vFire tool with Dynatrace
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
No updates on vFire.
