Limit on data sent through POST call to Dynatrace Server by RUM JavaScript
suresh230591
Mentor
How much amount of data RUM JavaScript can send to Dynatrace server in one POST call. What is the min and max time it should take to send data in call.
ChadTurner
DynaMight Legend
DynaMight Legend
the default max size of a beacon is 30kb, if it would grow higher than that it's split into multiple requests. the default limit can be configured using the `custom configuration properties` textbox within the advanced application configuration. just enter `msl=<size-in-bytes>`, so in your case `msl=4000` to decrease this limit. expect an higher amount of beacons though, since the beacon will be split if the content grows beyond 4kb.
-Chad
