Is it possible for Dynatrace custom dashboard to access external API's?
sgowda3
Newcomer
Is it possible for Dynatrace custom dashboard to access external API's (custom built REST API's which have the same health parameters as built-in Dynatrace API's) to show in the dashboard?
nj_njoku
Inactive
Hi Sandesha,
You may need to feed this data into Dynatrace as custom metrics using the Dynatrace API. Once you have done this you can view custom metrics on the custom dashboard. Please take a look at the documentation below on how to do this
https://www.dynatrace.com/support/help/dynatrace-a...
NJ
AgataWlodarczyk
Community Team
Community Team
That can be helpful as well:
https://www.dynatrace.com/support/help/dynatrace-api/configuration-api/dashboards-api
When passion meets people magic and innovation happen.
