Installing ActiveGate without checking a certificate
Would it cause a problem installing the ActiveGate without checking for a certificate during the installation and adding a mobile UEM monitoring for an Android app?
matthias_hochri
Dynatrace Pro
Dynatrace Pro
There is the property "DTXAllowAnyCert" for Android. The Android agent will then not care about a certificate. But we recommend this option only for DEBUG/DEVELOPMENT (!!) purpose as this is bypassing any certificate check.
Some more clarification: `DTXAllowAnyCert` is used to make the mobile agent accept self-sigend certificates. The certificate itself has to be valid (e.g. host name validation is not disabled).
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
