question
Anu S. avatar image
Anu S. asked ·
Explanation for Response of a REST API for Memory Used
I am calling a rest time series dynatrace API for memory usage and also obtaining the response. But I am not able to interpret the data that is obtained.
If I check the memory used on the dynatrace tool and compare the response obtained via the rest API the data does not match. I have attached screenshots of the same.
The first snapshot is of the host on the dynatrace tool. The memory usage shows 120MB.
The second snapshot is of the rest API call on postman which is fetching data but not sure whether its correct.
The URI of the rest API call is:
https://oxp944.dynatrace-managed.com/e/54a4f9ef-69...
Can you kindly provide some inputs here on how to read the response and validate whether it is correct?
Is there any detailed documentation on how we read the response data from the REST API's? If yes, kindly provide the same.
Anu
Dynatrace Managedrest apicloud foundry
1 comment
FYI no images have been attached.
0 Likes 0 · ·
1 Answer
Wolfgang B. avatar image
Wolfgang B. answered ·
Could you please give more context about the host? Maybe you are referring to the host memory limit for PaaS based hosts?
Share
