“NoClassDefFoundError” with Websphere after installing oneagent.
hiroshi_aoki
Dynatrace Organizer
Dynatrace Organizer
Have you experienced it? Do you have any idea
to workaround it…
4 REPLIES 4
Hi Aoki,
Without more details on the exception (e.g. which class is not found) it is hard to say what could be causing this. I would check the permissions of the account running WebSphere and see that is has read rights to the OneAgent install directory. If you are not able to provide logs here, it would be best to open a support case for this so your environment can be reviewed, it may be best to do that anyway.
hiroshi_aoki
Dynatrace Organizer
Dynatrace Organizer
Hi Markie,
The following is the detail of environment and error message.
************ Start Display Current Environment ************
WebSphere Platform 8.5.5.9 [BASE 8.5.5.9 cf091608.05][IBMJAVA7 7.0.9.30 cf091608.04] running with process name kksahp03Node01Cell\daswebc\daswebc_anadas and process id 374
Host Operating System is Linux, version 2.6.32-358.23.2.el6.x86_64
Java version = 1.7.0, Java Runtime Version = pxa6470sr9fp30-20160112_01 (SR9 FP30), Java Compiler = j9jit26, Java VM name = IBM J9 VM
was.install.root = /opt/IBM/WebSphere/AppServer
user.install.root = /opt/IBM/WebSphere/AppServer/profiles/Custom01
Java Home = /opt/IBM/WebSphere/AppServer/java_1.7_64/jre
ws.ext.dirs = /opt/IBM/WebSphere/AppServer/java_1.7_64/lib:/opt/IBM/WebSphere/AppServer/profiles/Custom01/classes:/opt/IBM/WebSphere/AppServer/classes:/opt/IBM/WebSphere/AppServer/lib:/opt/IBM/WebSphere/AppServer/installedChannels:/opt/IBM/WebSphere/AppServer/lib/ext:/opt/IBM/WebSphere/AppServer/web/help:/opt/IBM/WebSphere/AppServer/deploytool/itp/plugins/com.ibm.etools.ejbdeploy/runtime
Classpath = /opt/IBM/WebSphere/AppServer/profiles/Custom01/properties:/opt/IBM/WebSphere/AppServer/properties:/opt/IBM/WebSphere/AppServer/lib/startup.jar:/opt/IBM/WebSphere/AppServer/lib/bootstrap.jar:/opt/IBM/WebSphere/AppServer/lib/jsf-nls.jar:/opt/IBM/WebSphere/AppServer/lib/lmproxy.jar:/opt/IBM/WebSphere/AppServer/lib/urlprotocols.jar:/opt/IBM/WebSphere/AppServer/deploytool/itp/batchboot.jar:/opt/IBM/WebSphere/AppServer/deploytool/itp/batch2.jar:/opt/IBM/WebSphere/AppServer/java_1.7_64/lib/tools.jar
Java Library path = /opt/IBM/WebSphere/AppServer/lib/native/linux/x86_64/:/opt/IBM/WebSphere/AppServer/java_1.7_64/jre/lib/amd64/compressedrefs:/opt/IBM/WebSphere/AppServer/java_1.7_64/jre/lib/amd64:/opt/IBM/WebSphere/AppServer/bin:/opt/VRTSvcs/lib:/usr/lib:
Orb Version = IBM Java ORB build orb70-20151118.00
************* End Display Current Environment *************
[3/1/18 10:09:30:713 JST] 0000006b ServletWrappe E com.ibm.ws.webcontainer.servlet.ServletWrapper service Uncaught service() exception thrown by servlet ExportPaxList: java.lang.NoClassDefFoundError: org.apache.axis.deployment.wsdd.WSDDDocument (initialization failure)
�ȗ�
Caused by: java.lang.LinkageError: loading constraint violation: loader "com/ibm/ws/classloader/CompoundClassLoader@14062fbb" previously initiated loading for a different type with name "javax/xml/namespace/QName" defined by loader "com/ibm/oti/vm/BootstrapClassLoader@6c6ef511"
Hi Aoki,
Due to the LinkageError Exception I recommend openning a Dynatrace Support case for this to have the sensors reviewed for your Java environment.
hiroshi_aoki
Dynatrace Organizer
Dynatrace Organizer
Thank you for your advice. we have already open a support ticket .
