OpenKit SaaS Integration
jason_jenkinson
Participant
Hi
I have created an application (Digital Touchpoint Monitoring) and compiled the OpenKit dll's without issue. From there I have literally taken the SimpleSample from GitHub, compiled a console application and added my BeaconURL and ApplicationID.
When I run the application I receive 6 timesyncs as per documentation, however below is what I am receiving with reference to an invalid timesync. I have replaced the beacon and client details as below.
2018-03-09T15:49:40.5647130Z [DEBUG] BeaconCacheEviction thread started.
2018-03-09T15:49:40.5803132Z [DEBUG] HTTP Status Request: https://xxxxxxxxxx.bf.dynatrace.com/mbeacon?type=...
2018-03-09T15:49:42.3159358Z [DEBUG] HTTP Response: type=m&id=3&bl=150
2018-03-09T15:49:42.3159358Z [DEBUG] HTTP Response Code: 200
2018-03-09T15:49:42.3315360Z [DEBUG] HTTP TimeSync Request: https://xxxxxxxxxx.bf.dynatrace.com/mbeacon?type=...
2018-03-09T15:49:43.3307516Z [DEBUG] HTTP Response: type=mts&t1=1520610583143&t2=1520610583143
2018-03-09T15:49:43.3307516Z [DEBUG] HTTP Response Code: 200
2018-03-09T15:49:43.3307516Z [WARN ] The HTTPResponse "type=mts&t1=1520610583143&t2=1520610583143" is not a valid time sync response
This initially looks like an issue to me, however I receive a 200 response code and I have wrapped a condition around the IsInitialized and that returns true, however I am not seeing any data (Beacons) within DynaTrace SaaS.
I initially thought this could be a firewall issue but I have put the machine on open wifi and I receive the same results.
Any ideas/feedback would be very much appreciated.
stefan_eberl
Dynatrace Enthusiast
thank you for your feedback.
Unfortunately, you encountered a bug in the OpenKit .NET client, that has been fixed already. The appropriate pull request has been merged into the OpenKit .NET primary branch on Friday, March 9th at 07:29 UTC.
However, we do not recommend building OpenKit .NET from the latest primary commit, unless really required, since primary is an active development branch. We suggest downloading a pre-built binary from the releases https://github.com/Dynatrace/openkit-dotnet/releases
Best regards,
Stefan
jason_jenkinson
Participant
HI Stefan
Thanks for the update and confirmation that I downloaded the latest compiled dll and this is now working.
Regards
Jason
