OneAgent and BizTalk
jayne_martin
Guide
I have seen posts for integrating BizTalk and AppMon via Perfmon counters. Does the same concept exist for OneAgent?
denis_vanrijke1
Inactive
I also have a client looking for Perfmon counters using Oneagent/Dynatrace SaaS.. Is this coming soon?
Julius_Loman
DynaMight Legend
DynaMight Legend
You should be able to write your own Oneagent plugin retrieving metrics from Perfmon. You even should not need Python for that. You just need to write a correct plugin.json file describing metrics to be received and charts to be displayed.
I didn't try it, but according the ruxit.perfmon.dotnetV4/plugin.json that is available in the Windows OneAgent (in the agent\plugins directory) this should not be difficult.
The plugin.json reference is here https://dynatrace.github.io/plugin-sdk/api/plugin_json_apidoc.html
