Need info on how to instrument a React Native iOS mobile app to capture all user actions in the app?
gamalapa
Newcomer
Have done auto instrumentation steps for iOS as mentioned in the link How do I enable user experience monitoring for iOS apps . Also have added some keys like -DTXInstrumentWebViewTagging, DTXInstrumentAutoUserAction, DTXSendEmptyAutoAction,DTXInstrumentWebViewTiming along with the application identification keys in my info.plist file .With these steps I was able to see the user sessions , web requests etc on the Dynatrace applictaion Dashboard .But under the 'user actions' only few button actions like 'touch on OK Acton button' were captured . Need help on how to capture each and every user action in React Native Mobile application.
14 REPLIES 14
Patrick_H
Dynatrace Champion
Dynatrace Champion
currently ReactNative is not yet supported, but support for it is on the Roadmap.
Currently manual instrumentation should be possible as a workaround as @Kin Wai K. already wrote a plugin that allows creating manual actions.
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
Hi Patrick, could u please share plugin details?
Aftab
@Aftab A.if you send me your email address I can email the plugin to you.
Hi Kin, please share your plugin details to magogaba@gmail.com
Ganesh M
Hi Kin,
Can we get also the plugin (neumanyos@gmaiul.com) or better can you upload it to dynatrace github?
Thanks in advance
Yos
Hi Kin, Could you please share with me as well: charles.dudley at kaplan.com
Thanks!
Patrick_H
Dynatrace Champion
Dynatrace Champion
As I wrote above, the plugin is not from me and I did not use it yet myself - therefore I can't help you with that. Maybe @Kin Wai K. can help you.
aalam
Newcomer
@kin K. Thanks for help. Both Ganesh and I are working in same team. my email id is afty.iitr@gmail.com.
Could you please also confirm this plugin will work with Dyantrace SaaS or Appmon? we are current working on monitoring our react native app with dynatrace SaaS
Aftab
The plugin works for both Dynatrace and AppMon. The only difference will be in the ADK initialization call.
@Kin Wai K.
can you please email steps - ggcoolgg@gmail.com
Hi Gautam
Check github library - Dynatrace React Native Plugin at https://github.com/kwkoo/dynatrace-react_native_plugin
Yos
suresh230591
Mentor
Hi ,
Any news when this plugin will be in GA
This plugin itself will never be GA as this is neither developed nor officially supported by Dynatrace. React Native is still on the Roadmap but timeline is not yet fixed.
FYI @Dominik P.
rs00478708
Participant
Hi Kin Wai K,
I have been working on a project that needs iOS and Android mobile app instrumentation of ReactNative technology. Could you please share me the SDK API or the plugin for this as discussed in the above thread?
Thanks & Regards,
Rangapriya.
