How to integrate with https://www.webperformance.com/
mostafa_osama
Newcomer
JamesKitson
Dynatrace Guru
Dynatrace Guru
If you're asking how to integrate with load tests check out this blog post which also has a link to a performance clinic on the topic included:
https://www.dynatrace.com/news/blog/load-testing-r...
It does a good job of explaining what is currently possible.
James
