Using Log Analytics for SQL Transaction logs inside DB Tables
hmor3
Inactive
Hello Guys,
we need to monitor the SQL Logs that are written inside the DB Tables.
Is there a way dynatrace Managed Log analytics can read the logs inside DB Tables?
Himanshu Mor
3 REPLIES 3
pawel_brzoska
Inactive
Hi, that is currently not possible.
hmor3
Inactive
Thanks Pawel for the update!
Kindly let me know if this is in the roadmap for new release or we need to raise and RFE for the same.
Himanshu Mor
pawel_brzoska
Inactive
What is on the roadmap is logs import from any source through API. If you need specific support for SQL driver interface that would require RFE.
