• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
      • BSM Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Bharathi K. · Mar 27, 2018 at 07:28 PM · alerting monitoring synthetic monitors
Does Dynatrace trigger alert/problem when one of the locations for Synthetic tests go down(infrastructure issue/maintenance)?
Scenario: A synthetic test has threshold of 1 failure on outage handling. If there is is infrastructure issue/maintenance and if test fails at a location, will there be any alert generated for this failure?
Comment
People who like this
0 Show 0
10 |2000 characters needed characters left characters exceeded
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
· Add your reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Ugochukwu N. · Apr 02, 2018 at 04:57 PM
Hi Bharathi,
If your Outage handling settings in Dynatrace for your synthetic test is configured to alert when 1 location is unable to access your web application on first occurence, then yes it will create a problem and alert for this failure. If you do not want it to alert on this, there are a couple of options
  1. Modify your outage handling settings to alert on 2 or more locations and set it to 2 or more times consecutively for the failure to occur.
  2. Create a Maintenance Window in Dynatrace and set the scope to Browser monitor and clickpaths, Add a tag to this application and ensure that the maintenance window created in Dynatrace has a filter of the tag you placed on the synthetic test. See here on how to create maintenance windows in Dynatrace.
Please let me know if this works for you or if you need clarification on anything.
NJ
Comment
0 Show 4 · Share
avatar image Bharathi K. &. · Apr 02, 2018 at 05:02 PM 0
Share
If the Outage handling settings is configured to alert when 1 location is unable to access your web application on first occurrence and if the synthetic test fails due to Dynatrace infrastructure issues at Dynatrace locations, does the test still trigger an alert?
avatar image Ugochukwu N. Bharathi K. ♦ · Apr 02, 2018 at 05:09 PM 0
Share
Are you asking if an alert will be created if the Dynatrace node where the test is executed from is offline or down for some reason? That is it is unable to run the synthetic test? If that is what you are asking, it should not create an alert because if the Dynatrace node is offline or down for some reason, the synthetic test should not run at that location.
NJ
avatar image Bharathi K. &. Ugochukwu N. · Apr 02, 2018 at 05:14 PM 0
Share
Yes, that is what I am asking. If the Dynatrace node has some DNS issues or other infrastructure issues and when the synthetic test fails because of such errors, then does those failures trigger alert?
Can you please confirm if the Synthetic tests do not run for any Dynatrace infrastructure issues?
What happens if one node is down/offline and 2 other locations are good while my outage threshold is set to 3/all locations unavailable? Does it generate a problem?
avatar image Ugochukwu N. Bharathi K. ♦ · Apr 02, 2018 at 05:24 PM 0
Share
No it will not generate a problem as the threshold is to alert only when all 3 locations are unavailable. As 2 are fine, no alert will be created. For your other question, I am not exactly sure what the Availability SLA is for synthetic nodes but there is a lot of resiliency involved for the nodes in various locations. It isn't just dependent on a single infrastructure at a node location. You may want to discuss with your sales resource what this availablity SLA is for synthetic nodes and the details on the resiliency and failover for the nodes.
Hope This Helps
NJ
avatar image
Answer by Naventran C. · Feb 11 at 07:06 AM
So, can we conclude that there is no way to know if the synthetic test fails due to the locations' infrastructure issue ?
Comment
0 Show 0 · Share
avatar image
Answer by Suraj G. · Feb 11 at 01:30 PM
If I understand the above concern correctly, dynatrace announce/alarm if there is any issue with the dynatrace synthetic node.
You'll get alternate node options while selecting node.
Comment
0 Show 0 · Share
Your answer
Hint: You can notify a user about this post by typing @username
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
Welcome to the
Dynatrace Community Forums
Check out the Forum User Guide and Forum Guidelines to learn how to get started.
Community Member of the Month
February 2019
Announcing Dynatrace's Community Member of the Month for February 2019, Larry R.! Click here to read more!
Employee Member of the Month
February 2019
Announcing Dynatrace's Employee Member of the Month for February 2019, Dave M.! Click here to read more!
Live webinar: AIOps done right through enhanced Dynatrace AI root cause detection
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
NAM 2019 Beta is available
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Follow this Question
Answers Answers and Comments
24 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
How can I monitor 2 factor authentication login? 0 Answers
Is there a way to get an alert for monitored services? 2 Answers
Setup Alerts on HTTP Status Codes for oneagent 1 Answer
How to send Dynatrace the event of a load page to take more than 3 seconds? 3 Answers
how can I monitor or create dashboard in Dynatrace(Saas) for how many users are accessing particular webrequest in particular time with location? 0 Answers
Forum Tags
java user management dotnet redis docker ios davis log analytics gui mobileapp database cloud foundry usability services faq management zones user sessions test automation Dynatrace Managed amazon web services plugins php android javascript processes monitoring nodejs sso rest api appmon license dynatrace saas mobile monitoring user tagging installation nam aix oneagent sdk purepath network synthetic monitors apache hosts iis user actions paas azure http monitor linux mongodb mysql dashboard tipstricks rest openshift mission control activegate webserver servicenow kubernetes rum host monitoring cmc key user actions notifications openstack technologies configuration account continuous delivery tagging postgresql security smartscape high five award agent documentation alerting auto-detection cassandra administration vmware oneagent
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
    • BSM Open Q&A
