How to Instrument APK File for Android
rpichardo
Inactive
i need help to learn how to instrument a mobile app for android and IOS versions.
i have visual studio but can use gradle if need it too.
i have no experience on this type of configuration, so please be patient with me!!
1-i downloaded the agent, and unzipped.
2-i do not know how to start the Auto-Intrumentor..
3-i am lost with the rest of instructions...
4...
tyvm for your help!!
RKPO
4 REPLIES 4
nj_njoku
Inactive
Hi Robert,
I will suggest you follow the instructions here to do it via the command line. This contains very elaborate instructions on the instrumentation for Android. Also see link for using the Gradle plugin.
For iOS instrumentation, see link.
Hope This Helps
NJ
tyvm for your response, this is really great! i am following this instruction.!!
Thomas_Wirth1
Dynatrace Champion
Dynatrace Champion
Hello Robert,
Do you want to instrument a Xamarian app?
Currently Xamarian is not officially/fully supported and therefore you will not be able to fully monitor your app. R&D is already working on the Xamarian support and we hope that it will be available in the near future.
thank you Thomas,
i just read the fully instructions on how to auto-instrument and it work.
Now i am having more questions on how to continue instrumenting this app, also how to use all capabilities from dynatrace oneagent.
Regards.,
RKPO
