AppMon 7.1 integration with Dynatrace
AmitChiba
Helper
I have recently upgraded to AppMon 7.1 and done the integration with my on-Prem Dynatrace server. I have edited the System Profile and specified which metrics should be exported as per the link:
https://www.dynatrace.com/support/help/integration...
For testing purposes I am exporting CPU and Memory metrics for the host agents that I have in AppMon. When I try and create a dashboard in Dynatrace with the exported metrics from AppMon, I do not see it. I am not sure if the data is indeed getting sent to Dynatrace. Is there a way for me to confirm this?
5 REPLIES 5
thorsten_roth
Dynatrace Champion
Dynatrace Champion
Hi, did you read
https://www.dynatrace.com/news/blog/appmon-custome... ?
As you can see, you need at least version 143 for Dynatrace. I assume you run version 140, correct?
Thorsten
Aah, Thanks @Thorsten R. . I missed that article. I am currently on Version 140. Will wait for Version 143 and try again.
Wasnt it version 142 a couple of weeks ago?
c_zelabueno
Newcomer
Thorsten R. I'm working with Dynatrace 1.148.95.20180731-102751 trial license and I dont see any metrics pushed. How I can see if dynatrace rest endpoint is working as appmon expected??
Thanks!
Did you test the communication in the AppMon rich client? See server settings -> integration -> double click on config in the table and then click test connection.
