16 Apr 2018 06:38 PM
Hi Sergey,
Yes, please see this page for supported technologies: https://www.dynatrace.com/support/help/technology-...
Under Node.js you will find MySQL as a supported database framework. You may need to configure the MySQL built-in plugin as well. This can be done in your environment by going to Settings -> Monitoring -> Monitored Technologies, and configure the MySQL plugin.
Hayden
