Volume of data exchange between services
gautier_begin
Advisor
Using Dynatrace, can we evaluate the amount of data exchange between 2 services or 2 applications or 2 servers ?
ChadTurner
DynaMight Legend
DynaMight Legend
Yes, you can absolutely do that in Dynatrace. Dynatrace will see everything from end to end as long as the oneagent is monitoring the host and application.
-Chad
Hi Gauntier,
I believe below should satisfy what you need?
These should be answer the question of data volume exchange between servers and/or services. But for data exchange volume between application....maybe not.
