Problem Notification - Custom Integration with ProblemDetails as non HTLM-formated string
rodrigo_alvare1
Dynatrace Champion
Dynatrace Champion
In Problem Notification of a WebHook Custom Integration I would like to send directly the Problems details as plain text and not HTML-formatted. Is this currently possible?
Or this could be a RFE?
Thank you
5 REPLIES 5
adam_gardner
Dynatrace Champion
Dynatrace Champion
Hi Rodrigo, the following are currently available:
  • Text
  • HTML
  • JSON
  • Markdown
I believe the placeholder you need is:
{ProblemDetailsText}
juanjose_garci1
Inactive
Hi Adam, I´m involved in this issue with Rodrigo.
We have just put the Tag you mentioned: {ProblemDetailsText}, but it is empty.
This is a real result:
571|RESOLVED|INFRASTRUCTURE|CPU saturation|CPU saturation on Host Tomcat_portalprod08|{ProblemDetailsText}
Is there any other Tag could I use instead ?
Thank you.
Regards.
adam_gardner
Dynatrace Champion
Dynatrace Champion
Hi Juan, apologise, I wasn't clear initially. This is available on SaaS and is available on cluster version 143. Here's the blog post by our product manager @Wolfgang B.
juanjose_garci1
Inactive
Hi Adam.
Thank you for clarifying.
Let´s look forward to Dynatrace Managed Release 1.143 to test it
I¨ll keep you psted about my findings.
Regards.
juanjose_garci1
Inactive
Hi Adam.
The placeholder {ProblemDetailsText} is now available, but unfortunately it contains "CR" and "LF" characters, for example:
RESOLVED Problem 771 in environment qce29222
1 impacted infrastructure component
Host
oshiftinfra01.dpd.ieci
CPU saturation
8.17 % CPU usage
This becomes very difficult to use the value, for instance, if I want to run an OS Command form the Command Line passing the value as a Parameter.
Is there any way to get the same value as a single String no "CR" and "LF" characters ?
Thank you in advance.
