Sitecore (IIS + .NET) Monitoring with Dynatrace
anthony_pope-cr
Dynatrace Organizer
Dynatrace Organizer
Is anyone monitoring a Sitecore application with Dynatrace?
Have had luck monitoring them with AppMon + UEM in the past, but not Dynatrace yet.
Validation that they can be monitored with RUM and any special steps required would be appreciated.
pahofmann
If it works with appmon+uem there should be no problem monitoring it with dynatrace and rum.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
