Can the Dynatrace OneAgent also monitor IBM Mobile First Servers hosting hybrid mobile applications ?
vivek_bhandari1
Inactive
matthias_hochri
Dynatrace Pro
Dynatrace Pro
Basically you have to do some steps to be able to correlate WebRequests. As the WebRequests are sent via the adapters and triggered from JS part (but executed natively via OkHttp) they would always end up as a single WebRequest.
To be able to add the WebRequest under a certain action you need to pass the Dynatrace cookies to the real WebRequest. You can do this by using the JavaScriptBridge DynatraceJsBridge.getCookieForAction(actionId) and pass this value as Header "Cookies" to the adapter request.
