Dynatrace Davis VoiceOps Alexa requirements,
kjayaraman6
Participant
kjayaraman6
Participant
Dynatrace Davis VoiceOps Alexa requirements, whatare the other VoiceOps options if we dont have Amazon echo account.
do we need Alexa account and App on the mobile device to sent voice commands ?
How is the voice command lauched which is shown in the video https://play.vidyard.com/CokmHLU5M8Kmjh7sp4agAu
nj_njoku
Inactive
Hi Kamal,
In terms of VoiceOps options, there is the Davis web app and the Alexa skill. See links below on setup of both
Web App
Alexa Skill
You can also build your own custom integrations but they will not be supported by Dynatrace. See link below for all the info you need on VoiceOps options in Dynatrace
https://www.dynatrace.com/support/help/shortlink/s...
NJ
