Can we execute an Oracle SQL query and fetch the output in Dynatrace?
avishek_biswas
Newcomer
How to run a custom query in Dynatrace as part of a scheduled monitoring and fetch the output?
JamesKitson
Dynatrace Guru
Dynatrace Guru
This isn't possible within the product and would likely be the use case for a plugin, however I don't believe anyone has developed such a plugin yet.
James
AntonioSousa
