Can i get Bandwidth & latency details for a user?
azeez_mohammed2
Participant
Is it possible to identify if the network is slow at user end or Bandwidth,latency
gary_spencer
Inactive
Hi Azeez,
Keep an eye on this thread https://community.dynatrace.com/spaces/482/dynatrace-open-qa/questions/198662/does-oneagent-calculat... which is I think more the functionality you had in mind.
AlexanderSommer
Dynatrace Champion
Dynatrace Champion
As described in the referenced thread above, we will use new browser API's to get network details for browser sessions. But the requests for this feature are currently where low and therefore it is not on the short time roadmap.
You can create a product idea and describe your use case, perhaps we will get more quotes than and can give it a higher priority.
