Dynatrace Managed - DNS for Private Security Gateway
skanchalwar21
Inactive
Should we have DNS for Private Security Gateway? If yes, what are the benefits?
Babar_Qayyum
Hello Sandeep,
Define the entry point for the Security Gateway (for example, http://sg1.mydomain.com:9876). Via this URL, the Security Gateway is accessed by Dynatrace OneAgent. If not set, an auto-detected endpoint will be used. This entry can be used if the Security Gateway is accessed via, for example, an external IP address or load balancer.
Review the below link for more insight.
https://www.dynatrace.com/support/help/installatio...
Babar
