30 May 2018 07:26 AM - last edited on 09 Dec 2021 10:45 AM by MaciejNeumann
After a quick look on this blog entry by @Gatz, Bartosz (Bartek)
and regarding this sentence:
This is for Frame,lpar or both?
In case of AIX host with AME, what are the options?
31 May 2018 07:54 PM
03 Jun 2018 10:34 AM
Hi.
Today AME is not supported in any of the scenarios. We are assessing the general requirement to support this technology as well as technical aspects of supporting it.
Francisco, can I kindly ask you to provide a bit more background to your question? In what circumstances AME is used? Given the nature of underlying AME mechanisms, I am wondering about the applicability of this technology. Is this a prod environment, staging, or some other setup where memory availability is greatly more important than CPU? What services are running there? What types of problems, related to AME in particular, are interesting for monitoring, if at all.
Thank you,
Bartek.
04 Jun 2018 01:28 PM
Hi
All our AIX prod environments have AME enabled at LPAR level, we usually run IHS+WAS( IBM) or Oracle databases in those AIX servers.
We need to deploy Dynatrace oneagent in AIX and monitor these services, but as per this sentence
"AIX hosts with Active Memory Expansion (AME) installed are not supported for OneAgent deployment."
seems that we can't deploy oneagent in AIX servers using full stack agent.
05 Jun 2018 06:06 AM
Thank you Francisco. Much appreciated.
05 Jun 2018 03:34 PM
Hi @Bartosz G
Do you think we can roll out a mass deploy for AIX hosts or we must do it manually?
05 Jun 2018 07:34 PM
Hi Francisco. How do you plan to roll out multiple OneAgents at the same time? Do you have any particular software management solution in mind?
06 Jun 2018 09:19 AM
We will test Ansible or a custom script .
06 Jun 2018 02:28 PM
Hi Francisco. Ansible should work fine. You might want to check our Ansible scripts for OneAgent at GitHub: https://github.com/Dynatrace/Dynatrace-OneAgent-Ansible We have not tested them specifically for AIX, but this might be a good starting point.
