1 license multi tenant on Dynatrace SaaS
nkobayashi1
Helper
Could you tell us is it possible to have multiple tenants with 1 license?
According to the document, I think it is possible.
https://www.dynatrace.com/support/help/get-starte...
Noah
gerald_
Dynatrace Pro
Dynatrace Pro
Hi Noah,
yes, that's possible. The license is for an account and valid/shared for all tenants of that account.
Gerald
