How we create custom template for dynatrace Integration with service now .
vikas_sharma61
Participant
as we have assignment group as "Network " by default in dynatarce service now integration template . how we can change this attribute . Is there any way we can customize the template.
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
You could modify the 'Problem to incident' transformation map at the ServiceNow side and add your assignment groups there.
