easyTravel Demo Application - dynaTrace easyTravel Development Team please take a look at this - thanks
wesley_salek
Participant
I need an urgent help with the easyTravel Demo Application so it would run smoothly on my laptop. (I don't care about sending performance data to AppMon)
On Monday, Tuesday and yesterday, I used either "Version: 2.0.0.2758" or "Version: 2.0.0.2950" and both of them just "froze"/locked-up my laptop non-stop. I had to power off my laptop to get out from those "freezes".
I used easyTravelConfig.properties and easyTravelTrainingConfig.properties to launch easy Travel.
Please share with me a very stable easy Travel and info/configurations to run easy Travel in the "Training mode".
Many Thanks - Wes
3 REPLIES 3
steve_caron
Dynatrace Mentor
Dynatrace Mentor
Hi Wesley, I installed version 2.0.0.2892 (aka easyTravel for AppMon 7.1) on a Windows Server 2012 virtual machine yesterday and it's been running smoothly since then. I would suggest you use that version.
Rafal_Psciuk
Dynatrace Helper
Dynatrace Helper
Hi Wesley, can you give more details about your problem? I assume that freezes are connected with CPU usage.
Is it happens without any scenario started? If not, what scenario are you starting and how many visits is generated? CPU consumption may be caused by some problem patterns - did you enabled any of them?
wesley_salek
Participant
I'm all set right now.
I had AppMon and OneAgent running on my laptop. So - I uninstalled AppMon, and easyTravel is running as it should.
Thanks - Wes
