Is it possible to integrate LoadComplete ( Load testing tool by Smartbear) with Dynatrace OneAgent?
kumud_1_sharma
Inactive
4 REPLIES 4
JamesKitson
Dynatrace Guru
Dynatrace Guru
The answer provided here should apply to this question as well, check out the resources linked there for what is currently available and feel free to post and idea if it doesn't meet your needs:
https://community.dynatrace.com/spaces/482/dynatrace...
James
sonja
Inactive
You can integrate with any load testing tools by using custom HTTP headers and defining request attributes in Dynatrace. Here is an example of how to do it with JMeter: https://www.dynatrace.com/support/help/integration...
You only have to figure out how to add additional HTTP headers to your requests in LoadComplete 😉
Sonja
neeraj043
Newcomer
Hi Sonja,
I tried to integrate dynatrace with load complete with the steps given in provided url (For Jemeter) but it didn't work for me.
Could you please provide me the steps so that I can integrate my load complete with dynatrace?
Neeraj Kumar
I see you have created a new question (https://community.dynatrace.com/questions/207379/how-to-integrate-dyntrace-with-load-complete.html) - I will answer there directly.
