question
Fiona T. avatar image
Fiona T. asked ·
buildpack_sdk-for-nodejs_v3.20
Does Dynatrace Saas support IBM buildpack_sdk-for-nodejs_v3.20?
Thanks and best regards,
Fiona.
nodejs
1 Answer
Maciej N. avatar image
Maciej N. answered ·
Hello @Fiona T.,
In this documentation page, you can see all supported technologies and versions by Dynatrace:
Supported technologies and versions
The SDK for Node.js buildpack v.3.20 for IBM Cloud isn't on this list at the moment.
Share
