User with Management zone access not able to see default reports
pshinde
Inactive
We have created one management zone for some servers/application/services/process .In CMC console we have only given access and view log role permission to this zone . User is able to login to console after adding in Management zone group but in Report tab user unable to see any default out of box report. Kindly let me know if it is product limitation or I did some wrong while configuring the zones. Thanks
RomanW
Dynatrace Champion
Dynatrace Champion
Hi Prashant! That issue will be serviced in the support case you opened on June 13th.
pshinde
Inactive
Thanks for the udpate
