Can I control JavaScript injection according to user-agent?
menda
Guide
Hi.
I am using real user monitoring (RUM) on a certain site.
The site has access from smartphone and feature phone.
- SmartPhone Site: use JavaScript
- Feature Phone Site : not use JavaScript
The smartphone site and the feature phone site are the same domain.
I want to prevent JavaScript from being inserted on Feature Phone Site.
Best Regards.
franz_soengen
Inactive
Hi Masahiko,
I don't think that's supported out-of-the-box. The only way to configure JS Injection is by URL:
You just talked about the domain. Is there any other part of the URL where those two use-cases are different?
If that's not the case, you can also try disabling the agent via Javascript. In JS you should be able to determine which device you are on and if it's a feature phone you could call dtrum.disable()
best regards
Franz
JamesKitson
Dynatrace Guru
Dynatrace Guru
Not sure if it will help here but you can also include based on browser/device type and version:
The above is under the advanced setup for a specific applications settings.
James
