PCI DSS Compliance
Babar_Qayyum
Dear All,
I am looking for the answers of the below questions to be the part of the PCI DSS project.
  • Does the system receive
    full card numbers (Y/N)?
  • Does the system send full
    card numbers (Y/N)?
  • Does the system store full
    card numbers (Y/N)?
  • Does the system display full
    card numbers (Y/N)?
  • Does the system process full
    card numbers (Y/N)?
Babar
pahofmann
is it about credit card numbers? In any way, it depends on configuration.
Per default most likely not.
But a user could create a request attribute to capture the number or if the card number is contained in a log, it might be captured if log analytics premium is used.
Another posibility is RUM, where the number may be captured as part of a user action name.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
Hello @Patrick H.
Exactly. I am asking about the credit card numbers and looking for the generic information in the form of Yes or No to provide the information to the requested persons.
Babar
