Dynatrace integration with qTest
muthukumar_peri
Advisor
Is it possible to integrate Dynatrace with qTest with rest API? As soon as a problem ticket is created inside Dynatrace, we need to raise qTest ticket as we are using qTest as our ticketing tool. I couldn't find qTest in the Problem Notification tab in Dynatrace.
Can anyone suggest on this?
Regards
Muthu
JamesKitson
Dynatrace Guru
Dynatrace Guru
You can use the custom web hook problem notification for sending problem notifications to tools like that:
https://www.dynatrace.com/support/help/integration...
Good perf clinic here: https://www.youtube.com/watch?v=RkOPIxWewmI
You'll have to understand the APIs exposed by your ticketing tool.
James
Thanks, James.
Let me try and update the result here.
