Is Dynatrace Industy Associate certification still available?
jeff_rowell
Helper
I was trying to find the link to the APM Industry Assocaite certification information on the APM Univeristy website, but I am no longer able to find it. Is this still a valid certification and, if so, what is the link no longer accessible via the website?
5 REPLIES 5
JamesKitson
Dynatrace Guru
Dynatrace Guru
I see it on the certification page:
https://university.dynatrace.com/certification/dyn...
Where are you looking for it?
James
jeff_rowell
Helper
No, that link takes you to the Dynatrace certification info. What I am referring to is a technology neutral certification that used to exist (I believe the name was APM Industry Associate)... I no longer see any links to that on the University website, so I presume it is no longer offered... if you google you can still find links to the certification page however.
Oh, yeah that was the APM Industry. I haven't heard about that in a long time. It's not even one you can schedule anymore so I would assume it's just no longer something offered. Haven't explicitly heard that though.
JamesKitson
Dynatrace Guru
Dynatrace Guru
I got some feed back and yes the 'APM Industry' certification has effectively been retired at this point. Just the product certifications you see in University are the ones that are currently available.
James
srossells
Visitor
https://university.dynatrace.com/certification/industry
