OneAgent Extension didn't enable log monitoring by default
waikeat_chan
DynaMight Pro
DynaMight Pro
It seems like it didn't, because for every Virtual Machine in Azure where the OneAgent extension is installed, this is what I see:
Or is this the behavior if I installed the extension in Azure VM? (i.e the default setting of enable log monitoring is only enabled if I installed the extension in Azure WebApp, but not Azure VM)
4 REPLIES 4
Julius_Loman
DynaMight Legend
DynaMight Legend
At least for Linux (I guess it is the same for Windows) you need to explicitly turn on log monitoring at installation time with the parameter APP_LOG_CONTENT_ACCESS (the default value is not to turn on this feature, unless you specify the value "true" or 1 for this parameter).
How exactly did you install your Windows agents?
After login to the Azure Portal, I've intalled it using the GUI way as outlined here: https://www.dynatrace.com/support/help/cloud-platforms/azure/how-do-i-deploy-oneagent-to-azure-compute-vms/
waikeat_chan
DynaMight Pro
DynaMight Pro
I installed the OneAgent Extension to these VMs, its not like, I RDP into these VMs, then double click to run the OneAgent installer in them.
pawel_brzoska
Inactive
