Code level CPU time in ms versus contribution
brian_mcgee
Newcomer
When viewing CPU information for .NET code level, is it possible to show CPU time in ms instead of CPU contribution in percentage?
3 REPLIES 3
Babar_Qayyum
Hello Brian,
If you are talking about the exec CPU Time then in the PurePath Tree by default it is in the [ms] or if you are asking for some other location then share the screenshot with us for better understanding.
Babar
brian_mcgee
Newcomer
Hi @Babar Q.,
I can see duration at PurePath code level but not at the level of detail I need.
For ASP.NET modules I see contribution percent for each method. I would like to see duration in ms for each method.
Brian
Hello Brian,
I thought you are taking about AppMon but the screenshots are taken from the Dynatrace.
I would recommend you to move your post into the Dynatrace forum to get solutions from the other experts.
Babar
