Is admin right needed to generate user access token
raja_oswal
Newcomer
Not able to see Settings tab and Integration tab after logging on to Dynatrace
nj_njoku
Inactive
Hi Raja,
The User Group your account belongs to has to have the permission to Change monitoring settings to be able to see the Settings tab and the Integration tab. You may request your admin grant the group you belong to that permission or move you to a group that has that permission.
NJ
