PurePath stopped at DataPower level
g_ciret
Contributor
We face an issue monitoring calls through a DataPower.
A monitored service calls a monitored web service through a Datapower but the purepath can't track the calls through it. We only see calls to an unmonitored host for these calls.
I have checked with the network team and we see 3 headers in the requests (X-Forwarded-For, X-Client-IP and X-Global-Transaction-ID), and one header in the responses (X-Global-Transaction-ID).
Is that OK, or should I see other headers (X-dynaTrace)?
Thanks for your help.
6 REPLIES 6
nj_njoku
Inactive
Hi Giles,
Yes, to see the transactions go through the Datapower tier, you have to ensure that the X-dynaTrace header is not stripped and is passed through Datapower to the next tier. This is what I did to see my transactions go through Datapower.
NJ
Hello Ugochukwu;
Do you know where I could apply the configuration in the datapower?
Thanks for your answer.
RGuerrero
Hi NJ!
Could you please share any details regarding the DataPower configuration? We are currently also facing this issue.
Thank you in advance!
Regards
Arild
g_ciret
Contributor
Hi Ugo,
I'll check this.
Gilles
g_ciret
Contributor
I come back to this issue. My customer confirmed that the x-dynaTrace header is stripped.
But they did not find an easy way to configure the whole Datapower to copy the incoming request header to the outgoing request without having to set up a rule on each service (more than 200).
Did anyone find a solution to apply that rule to the whole Datapower config?
Thanks.
Gilles
Ab3dn3g0
Frequent Guest
hi All,
i have same issu with dynatrace not allow x-dynatrace header after IBM DP, on proses MQ, there are solution how to allow x-dynatrace header on MQ, to show service flow end to end.
need help for some documentation for allow Header on MQ Proses.
Thnks
