Alerts for EBS & EFS mount failures in EC2 instance
muthukumar_peri
Advisor
Do we have a mechanism in Dynatrace to alert us if we lose EBS & EFS mounts from an ec2 instance?
Regards
Muthu
3 REPLIES 3
muthukumar_peri
Advisor
I found that currently we don't have the option to alert if a volume fails to mount. I have raised RFE for the same.
https://community.dynatrace.com/spaces/483/dynatrace...
antonio_elfarkh
Participant
Hello, i need to monitor the EFS partition . Is it possible with Dynatrace ?
michal_nalezin
Dynatrace Advisor
Dynatrace Advisor
Hi Antonio,
I'm not sure if this is correct topic for your request.
If you are interested in AWS EFS performance metrics, please take a look on this EAP.
Best regards
Michal
