10 Jul 2018 09:31 AM
we are finding some Openshift PODs which are detected twice with different Service Names (default-hosts and local-hosts). Two questions:
- Do you know why do we see it twice?
- Is there any way to know which Service name rule is being applied for each services? (built-in Service Name rules or custom).
Thanks.
Alberto.
10 Jul 2018 03:48 PM
Hi Alberto,
Go to the service page for both services and expand the Properties and Tags on the service page. This should give you more information on the difference between the 2 services.
NJ
12 Jul 2018 09:08 AM
Hi NJ,
unfortunately it is not possible, as far as I am checking, to see the Built-in Service Naming Rule applied for each service:
As you can see, the Service is a "Web Request" but there are several Rules for Web Requests, which one is applied? That's what I want to find out.
Regards.
Alberto.
