OneAgent outputs logs into Syslog?
nkobayashi1
Helper
Could you tell me whether OneAgent outputs the log into Syslog especially when the OneAgent has some trouble or consumes much hardware resources?
Thanks, Noah
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Noah,
The OneAgent does not log anything into syslog, all the logs produced by OneAgent are stored under /opt/dynatrace/oneagent/log on Linux. See also the following help page:
https://www.dynatrace.com/support/help/shortlink/o...
Tomasz
