Dynatrace JDBC information
ajdimanuel
Inactive
is it possible to get JDBD DataSources info from AppServers?. AppMon brings that information easily but I don't find out hoy to get it from Dynatrace.
The thing is that I need to get it from Dynatrace API to feed Splunk.
Thanks in advance.
Alberto.
david_alonso
Dynatrace Champion
Dynatrace Champion
There is no default view where you can get the information of the JDBC Datasources. You can in the other hand get using the JMX bean and getting the metic that you can use later to see on the process metric and chart it in custom charts.
For that you need to activate the JMX metric capture in your tenant.*
I hope it helps.
Hi David,
Please help to activate the JMX metric capture for "Connection Pool" metrics in JBoss?
Thanks & Regards,
Jalpesh
