Secure attribute of cookies of RUM
nkobayashi1
Helper
According to the document, it seems possible to set secure attribute of cookies of RUM.
You can use theSecurecookie flag, however this leads to loss of visibility into any unencrypted HTTP communication.
https://www.dynatrace.com/support/help/data-privacy-and-security/data-privacy/how-does-dynatrace-use...
Could you tell me how to do that?
Where is the setting?
Thanks, Noah
AlexanderSommer
Dynatrace Champion
Dynatrace Champion
Please take a look at the advanced settings page - cookie section in your application configuration.
Thank you for your answer.
It's very helpful. I missed the settings.
