Event type - "FAILURE_RATE_INCREASED"
skanchalwar21
Inactive
Event type - "FAILURE_RATE_INCREASED" does not seem to be documented anywhere. Any idea what kind of alert it is?
3 REPLIES 3
jan_palic
Guide
Hi @Sandeep K.,
every call in your platform between client and service has a general failure rate; ideally near zero.
Dynatrace will notice, if the rate is increased in comparism to the last seven days (if I am not wrong).
In this case, you will see a problem or get a notification (depends on your configuration).
Best,
Jan
Joe_Hoffman
Dynatrace Leader
Dynatrace Leader
What Jan said +1.
Another way to look at this is to go into the Transactions & Services view within Dynatrace, select the Failure Rate column, then switch to the Graph view. This will give you a historical perspective of failure rates over time with the large contributors showing up in the graph. Be sure to select a time range which covers the time when the increase was reported.
Andrew_Belford_
Newcomer
Is that means FAILURE_RATE_INCREASED is available under all "Event type" if that is the case?  I can't see it on the "Event type" documentation online its available under a specific Type
