Data retention period of synthetic
nkobayashi1
Helper
Could you tell me how long synthetic monitor data kept in SaaS?
I would like to know the period of the following data.
  • Duration and availability of the entire monitor
  • Each metrics for per action
    Action duration, Server consumption, Network consumption, DOM interactive, Speed index, Visually complete
  • Waterfall chart
Noah Kobayashi
3 REPLIES 3
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi @Noah K.,
  • Duration, Availability, and all the metrics you mentioned are timeseries data and are therefore kept for several years (get aggregated over time).
  • Waterfall charts & screenshots are kept for 35 days.
Kind regards, Philipp
dave_rick
Participant
Another part of the request was:
Being able to graph out each step/action would be very helpful for dashboards. I am wondering if this needs to go into a new enhancement request.
Hi Dave,
those metrics are also stored as timeseries on per action basis. We are currently working on making in possible to also select them for custom charting.
